engines
Posted: Sat Feb 13, 2010 10:49 pm
by janowich
Hi
Last summer I get a boat without engine. So I want build in a diesel engine from German car (like Mersedes our BMW)
So, I want to know how powerfull I need??? What do you recommend???
If you need spare parts from gaz engine - welcom :) My grandfather was driver on gaz53 truck. So I can help. And I can help with wood (iroko) for boat deck
My e-mail janowich@inbox.lv
Re: engines
Posted: Mon Feb 15, 2010 7:40 pm
Dear Janovic,
Thanks for message: I am just repairing my GAZ and I think I have most spares already bought.
For your request I advise to use the same propeller revolution and change only engine & Gearbox accordingly.
Providing you have still the original propeller and propeller shaft, you should use a modern diesel or gasoline
engine in combination with a ZF 63 IV gearbox and you should match the reduction ratio of the gearbox
in such way that you end up with the same propeller rpm like the original design. In the Forum you can
see under ''Repair of 6 Volgas'' the suitable gearbox and their reduction ratios available. Please not forget
that you have to marinize your engine with watercooling and exhaust cooling etc...
Please contact me if you have any furter questions.
best regards
Re: engines
Posted: Mon Feb 15, 2010 10:54 pm
by janowich
Former owner is a old man, who drives on that boat (I get to know, that my boat is "Strela"). He told me a lot of gaz engines, adventures with boat and etc. New he is to old to repair it...
Re: engines
Posted: Thu Aug 04, 2011 11:16 pm
Dear Ed,
Thank you for your e-mail. One of my major concerns were, that this site was always in english and not in other languages. For me or some others it does not matter. There are so many chaps out there, that might have good comments, but just hesitate as they think they are not good enough in English to join a statement. This is a pitty and I SAY LOUDLY TO THOSE: Write in your own Language! Russian, Dutch, Deutsch, Francaise, Türkçe, Africaans, H'rvatska, Espanol or 3rd class broken cockney English .... who cares? we all share our same hobby and nothing needs to be in a distinct language ...
This is an international site of Volga adicts and there are several internet translation programs.
Never mind the Bollocks
I broadcast your message as is ... Sorry, if this is a problem for you.
Sent: Sunday, July 31, 2011 6:34 PM
To: 'Georg Weinstabl'
Subject: Volvo B30
Hallo Georg,
Ich war gerade dabei wieder auf die Webseiten zu lesen als ich darauf kam was du über die bis jetzt bekannten Volga Motorentypen geschrieben hast.
• 6-cyl GAZ engine + reverse reducer + V-drive (as your '65)
• 8-cyl GAZ engine + hydro reducer + V-drive (as your '8x)
• 8-cyl Volvo engine + Z-drive (export version)
Als ich damals über mein Volga geschrieben habe hatte ich schon erwähnt das ich einen Volvo B30 hatte
Ich fand bei Wikipedia folgendes
Volvo B30 engine
From Wikipedia, the free encyclopedia
This B30 was a straight-6 automobile engine produced by Volvo Cars starting in 1969, and used in the company's 164 sedan from 1969 through 1975. It was also used in the Volvo C303 military vehicle. Other uses included marine, industrial and agricultural applications. It was a robust pushrod engine using timing gears and displaced 3.0 L (2978 cc/181 in³). Basically it's a B20 with two added cylinders. Output ranged from 130 hp (97 kW) with the B30A equipped with two Zenith-Stromberg 175CD2SE sidedraught CD carburetors to 160 hp (119 kW) (SAE net) from the higher-compression B30E equipped with Bosch D-Jetronic electronic fuel injection. The engine offered smooth running and high levels of torque at low engine speeds.
Hinzugefügt habe ich die Bilder vom Originalmotor aus meinem Volga dies ist also einen B30.
Laut meine Original-Notar-Akten sollte der Motor eine Leistung von nur 90PS haben
Vielleicht ist es nützlich deine Liste mit den - 6-cyl B30 Volvo engine + Z-drive (export version) -zu erweitern? ige dinge die ich hierzu au Y
Sonstige Bilder die ich auf Youtube gefunden haben im Bezug auf B30 und den AQ170 Sterndrive
http://www.google.com/url?sa=t&source=w ... PWzLAEZW1A
http://www.youtube.com/watch?v=X4sKEVhW ... re=related
Einen schönen Gruß aus Emmerich,
Ed
Re: engines
Posted: Sun Sep 25, 2011 8:37 am
Here you can see a restored Volga 70 boat engine:
http://www.youtube.com/watch?v=5qi5sjbJM08&NR=1
The engine here is being indicated as a GAZ-13. It looks similar to my GAZ 53L. Nice sound!
